Author Topic: Tire problem  (Read 992 times)
Offline Mudhawg
  • Rig Life
Tire problem
« on: January 04, 2007, 12:30:57 PM »
Ok one of my 35" baja claws has a maybe 1" cut on the back side of it... were would i take this to have it fixed? (would need to be pulled off the rim im guessing
1984 Chevy 6" Lift 40" Boggers
Offline GiS
Tire problem
« Reply #1 on: January 04, 2007, 12:36:20 PM »
On a sidewall or tread block?
If on the sidewall, pull the tire off rim and use a nice big patch,
Take it to Jamie and OK Tire in Shawney (sp?) station off MacLeod, fellow wheeler and a great guy.
stuckagain
Tire problem
« Reply #2 on: January 04, 2007, 12:38:10 PM »
which direction is the cut in relation to the bead of the tire?if it is vertical from the bead (points at the bead) I can repair it. If it runs the same direction as the bead it may not be repairable.
Offline Mudhawg
  • Rig Life
Tire problem
« Reply #3 on: January 04, 2007, 12:45:33 PM »
its side above were the tread and sidewall connect between 2 tread blocks... i was thinkin just patch the hell out of it and maybe put in a tube... truck it is goin on is offroad only
joey your talkin about Jamie right?
Offline GiS
Tire problem
« Reply #4 on: January 04, 2007, 01:28:00 PM »
Jamie = Littleguyracing  8)
Offline Mudhawg
  • Rig Life
Tire problem
« Reply #5 on: January 04, 2007, 03:04:01 PM »
Any idea how much he will charge?
