Author Topic: Bnine helps  (Read 1766 times)
Bnine helps
« on: January 15, 2007, 10:16:29 AM »
Thanks Bill for doing the 5.13 gears and CTM's. The jeep is flawless with your install. No noises what so ever. What a difference!
i have said many times that 4.11 gears and 37's are ok, and i still believe that BUT :lol:  5.13's are so much better. i got 5th gear back and 4th gear accelerates. My rig is fast again.
The CTM's should help out as well.
Thanks again. Good seeing you there Dom.
We'll be back in 500kms to change the fluids and do all the brakes. The brakes need done but i am happy that 37,000 kms with 37's on her lasted this long. i am a light braker :D
Tom :)
Re: Bnine helps
« Reply #1 on: January 15, 2007, 10:27:09 AM »
It was nice to see you too Tom.
Bill has done a great job with my gears also. Flawless...indeed.
I will let you know where to find the Teflon grease for your CTM shortly.
Cheers
Bnine helps
« Reply #2 on: January 15, 2007, 11:22:19 AM »
Thanks Tom, glad to help.
See you in a few hunered k's  :D  :D
Bnine helps
« Reply #3 on: January 15, 2007, 11:28:40 AM »
I bet it's like driving a whole different Jeep now.
Vince
Bnine helps
« Reply #4 on: January 15, 2007, 12:14:04 PM »
Thanks Domm for following up on that.
Vince, Yes a different jeep for sure. Now i have to GPS the speedo again as it should be closer to 'normal'.
See ya in a couple weeks Bill.
Tom :)
Bnine helps
« Reply #5 on: January 15, 2007, 12:32:58 PM »
Quote from: "Spinalguy"
Tom :)
With 35's my speedo was reading about 15% fast.
Superlift's Truspeed unit fixed that, it's out by about .5 Km/h now.
Vince
Offline RckyMtnTJ
    • http://www3.telus.net/lck
Bnine helps
« Reply #6 on: January 15, 2007, 02:12:54 PM »
On a similar topic, whats the proper break in protocol?  A friend just got some gears and lockers installed in his rig.  So to keep this on topic as a Jeep topic.  If one had Warn Hubs and got new gears and lockers, what would be the proper break in to make sure that the front was turning as well?  Do you:
a) Drive it in 2wd
b) Lock er into 4hi
c) engage your transfercase into 4hi, but not dial in your hubs.
d) dial in your hubs, but keep it in 2hi
e) some other option
Also what is the correct length of time/speed required?
Thanks, and congrats Tom on the the gearing.  I'm sure you'll love it.
Jeff
98 TJ 4" lift + goodies
Bnine helps
« Reply #7 on: January 15, 2007, 02:17:16 PM »
You want to heat them up and let them cool down on there own for at least 2 cycles.
Then run them until around 500k and redo the fluids to remove any break in material.
I dont know if just engaging the t-case will work them hard enough. I'd say hit the highway for a quick 10-20k with everything in so they have some load on them. Get them nice and hot, then let them cool on their own. Repeat that once or twice more.
Thats one of the more cautious ways to do it.
Also, if you dont live an hour from work, the commute for the first week or so should accomplish the same thing.
hth
80CJ
Bnine helps
« Reply #8 on: January 25, 2007, 10:11:24 PM »
Didn't know you did gears Bill. Since I now know I have a question or two. I recently had my gears on my Tacoma swapped. During the break in procedure (I did everything that everyone told me) the truck never went over 50 mph and I only locked it in on dirt, didn't wheel it at all, just locked it in on a dirt road to get some run time on the front end. Well at about 135 MILES the front end took a dump. Ultimate cause was deemed to be the outer pinion bearing. They said I broke them in improperly although I followed Rany's Ring and Pinion break in procedure the letter. They said that if it was bad setup both bearings would have gone. Any input good buddy? Thanks. Sorry for the hijack Tom, but you seemed done with this thread and I didn't want to start a new one about a Toyota on a Jeep board although I am in the market again. P.S. went from 410's tp 4.88's and everything was new, bearings, seals, gears, and what not.
Bnine helps
« Reply #9 on: January 26, 2007, 08:10:33 AM »
Improper prelaod, possibly to tight at set up, to loose would effect both I think, but not positive.
Defective bearing
Improperly seated race
spun a race
Damaged bearing prior to install
Re used original race
Brass or other punch material left behind
no prelube for the bearing
low oil level
Thats a few of things I know can effect that bearing. Imposoble to say exactly what it is. All just possibilities.
My guess would be preload related either due to torque setting or bearing seating. Or a bad/damaged bearing. Still, those are just best guesses.
Re: Bnine helps
« Reply #10 on: January 29, 2007, 12:54:15 PM »
I can't believe you were running 37s and 4.10s, that must have been brutal on the highway
