Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
ZJ 4WD Switch
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ZJ 4WD Switch (Read 1662 times)
Iron James
Guest
ZJ 4WD Switch
on:
January 21, 2007, 04:42:04 PM »
The on board computer in my 93 ZJ beeps once in a while, moslty on longer trips and says "Service 4WD Switch". Does anyone have any idea what might be happening? My 4wd works great in high and low. Could it just be a sensor? If so where is it?
- Joel
Logged
Iron James
Guest
ZJ 4WD Switch
Reply #1 on:
January 23, 2007, 09:38:19 PM »
Anyone?
Logged
kevman
Budget Lift
ZJ 4WD Switch
Reply #2 on:
January 23, 2007, 10:23:59 PM »
Did you search jeepsunlimited.com? I remember reading about this before. If I recall correctly it's just got something to do with the computer and doesn't necssarily indicate that something is wrong.
Logged
uh...
My shovels nicer!
JackstandJohnny
Talks waaay too much!
where Jeeps go to die
ZJ 4WD Switch
Reply #3 on:
January 23, 2007, 11:32:08 PM »
james you could also try
www.nagca.com
too. lots of knowledgable people on there......... good luck
Logged
~ rescue green JKUR on 35s. typical rubicon build
frenchy
ZJ 4WD Switch
Reply #4 on:
January 23, 2007, 11:58:37 PM »
I've heard that the switch could be tripped by low fuids in TC. I would check that first.
To find the switch, look from he drivers side near the top of the Transfer case, should have 4 wires. I'd check the wires first, then replace the part.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
ZJ 4WD Switch
