Author Topic: ZJ 4WD Switch  (Read 1669 times)
Iron James
ZJ 4WD Switch
« on: January 21, 2007, 04:42:04 PM »
The on board computer in my 93 ZJ beeps once in a while, moslty on longer trips and says "Service 4WD Switch". Does anyone have any idea what might be happening? My 4wd works great in high and low. Could it just be a sensor? If so where is it?
  - Joel
Iron James
ZJ 4WD Switch
« Reply #1 on: January 23, 2007, 09:38:19 PM »
Anyone?
Offline kevman
    • http://members.shaw.ca/thekevman
ZJ 4WD Switch
« Reply #2 on: January 23, 2007, 10:23:59 PM »
Did you search jeepsunlimited.com?  I remember reading about this before.  If I recall correctly it's just got something to do with the computer and doesn't necssarily indicate that something is wrong.
uh...
My shovels nicer!
Offline JackstandJohnny
  • where Jeeps go to die
ZJ 4WD Switch
« Reply #3 on: January 23, 2007, 11:32:08 PM »
james you could also try www.nagca.com too. lots of knowledgable people on there......... good luck
Offline frenchy
ZJ 4WD Switch
« Reply #4 on: January 23, 2007, 11:58:37 PM »
I've heard that the switch could be tripped by low fuids in TC. I would check that first.
To find the switch, look from he drivers side near the top of the Transfer case, should have 4 wires. I'd check the wires first, then replace the part.
Jeep
With stuff
