Author Topic: Fluids  (Read 840 times)
tymbre1
Fluids
« on: May 15, 2007, 12:26:33 PM »
Trying to save a little money here so any info would be greatly appreciated.I need to change gear oil in both diffs on my 99 tj (front d30 rear d 35 c) I have no idea how much gear oil for each case or what the best brand and weight.Also would like to service the fluids in my transfer case any info or links greatly appreciated.  :D
Fluids
« Reply #1 on: May 15, 2007, 01:20:32 PM »
Axles are gear oil - 75 or 80w90 GL-5, I just use regular dino oil.  Both will take a little over 1 litre, 3 litres will do you good.  However, if you have a limited slip in the D35, you will have to go to the dealership and grab some $10-15 friction modifier for the diff
T-Case uses ATF, Dexron III or better, about 1.5 litres
Fluids
« Reply #2 on: May 15, 2007, 08:34:05 PM »
if you're going to crack open your diffs to change fluids. then maybe take the few extra minutes to change your rear axle seals. if they arent leaking then leave them but if they have a hint of seepage then change them both out. the fronts arent easy to change so dont worry about them unless they are badly leaking. if your extension housing seal is leaking on your t-case(most np231's leak at this seal) then change it too. no point putting new fluids in when they will just leak out. if you know you're going to keep the fluids in there for a while then check out synthetic fluids. much nicer on everything, especially in winter.
tymbre1
fluids
« Reply #3 on: May 15, 2007, 11:03:08 PM »
Thanks guys looks like good advice.
