Author Topic: welding  (Read 811 times)
evasion1
welding
« on: June 27, 2007, 08:06:35 PM »
i need to weld to new shock monts  on the rear alx on my jeep  any one done this befor  ? any info would help   thanks
80CJ
welding
« Reply #1 on: June 27, 2007, 10:49:39 PM »
Well I've never done it on a Jeep but I'm guessing you're going to want some sort of twin shear mount and locate it towards the bottom or center of the axle tube to help with axle wrap.
Offline rws
  • Stump Grinder
welding
« Reply #2 on: June 28, 2007, 08:08:44 AM »
Modern sells cheap shock mounts that fit on most axles. Measure carefully flexed and un-flexed that the rangeof travel the shock will go through, it is very important that the shock neither bottom out or top out.  If either of the above happens your shock mount will break off the axle.
