Author Topic: Blower motor stoped working  (Read 1207 times)
Offline 01sahara
« on: November 12, 2007, 03:50:23 PM »
A small technical difficulty has started with my 2001 TJ.  The fan for the blower motor has quit.
It is not the fuse checked that its ok.
I have ordered a new switch, for the last year the high speed had quite working, the rest of the speeds may have quit.  Switch will be in the next few days. I hope that is the problem.
I understand that the blower motor also has a resistor that could be the problem or the motor it’s self. Has anyone had any experience with these items going or how to test them?
Blair
Offline Gearhead
« Reply #1 on: November 12, 2007, 04:52:44 PM »
I hear the heater control circuits in TJ's is somewhat overloaded and tends to melt switches / wiring  . Is there not a fix ? that involves diodes to protect switches ?
Offline calltrex
« Reply #2 on: November 12, 2007, 05:31:32 PM »
ive changed lots of blower resistors with my vehicles
Older blowers can also keep blowing the resistors so then u have to change both.
u can risk just changing the resistor but if it blows then u just wasted $30
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Offline Rookie
« Reply #3 on: November 12, 2007, 07:27:52 PM »
Blair
Had the same thing happen multiple time's and have replaced the switch every time fixes the problem for a while but the problem comes back  :!:
When the switch go's it melts the wiring in the harness you have to cut off the factory end and replace it with insulated female blade crimp conectors
Gimmie a call and I'll explain it better
TJ with some stuff
Offline 01sahara
« Reply #4 on: November 12, 2007, 08:52:59 PM »
Quote from: "Rookie"
Blair
Thanks Steve. I will call once the part is in. I had not noticed that the harness was melted but will take a closer look. Thanks.
Offline Gearhead
« Reply #5 on: November 12, 2007, 09:45:35 PM »
There was an article in a recent JP magazine about this , I believe they used a relay to fix the problem.
Offline 01sahara
« Reply #6 on: November 12, 2007, 09:51:58 PM »
Quote from: "Gearhead"
I will do a search and see if I can find it.
Blair
