Author Topic: 2k TJ questions regarding tire sizes  (Read 1276 times)
Offline Chiram000
« on: December 13, 2007, 09:01:12 PM »
Hey guys fairly new to the jeep although the Comanche i had a few years ago was indestructible...  Anyways, I Just picked up a 2k Jeep TJ with the 4 cyl in it and im wondering what sort of limitations i should be looking at as far as rubber, and a few other things I should be looking at swapping asap.
Im looking at going with a 3.5" Rubicon express super flex lift and the appropriate rubber, however, I don't want to be the guy driving up a hill on the high way doing high rpm in 3rd or something. With that said where lies the limitations of a reasonable tire size?
Im not looking into going into some heavy mods, just enough so i can get back out into the bush to go camping and have a bit of fun.
Thanks for answering my newbie questions,
Tyler
« Reply #1 on: December 13, 2007, 09:36:53 PM »
Tyler, a 32 x 11" bfg AT is about the max you can go. Even then, you WILL be the guy struggling in 4th going up a hill and sometimes hitting 3 at the top.
The reason for the brand is the weight, the bfg at is among the lightest tire on the market, and one of the only brands that come in a 32" size.
You could run a 31" tire, but it would look funny on a RE 3.5 lift.
Only way to handle a larger tire on the road with a 2.5 is to regear the axles. Stock is 4.10, lowest you can go is 4.88, which can handle a 33" tire if you keep the rig weight down.
Good luck
« Reply #2 on: December 14, 2007, 07:08:19 AM »
When I had my 4 angry squirrels and 31s and I was mostly 4th and 5th on the highway, but some hills, like in the mountains, I needed a little 3rd every now and then.  However, when I went to 33x12.5s, I was in 3rd a lot and not so much in 5th.
It is a tough call but if you want to run bigger tires you will need to regear like Bnine said
Offline Chiram000
« Reply #3 on: December 14, 2007, 07:45:54 AM »
Well im not extremely set on the 3.5" lift, but anything is an upgrade over factory. Thanks for the info guys, i'll definetly start taking a look into re gearing and those tires.
