Author Topic: Swappability between YJ and TJ  (Read 2748 times)
« Reply #15 on: December 26, 2007, 08:24:53 PM »
Not as far as I know, although the reverse is true (AX-15 bolts to the 2.5 engine) if you use a Dakota bellhousing from the 2.5 tranny for the AX-15. I was asking about this on Eco and was told to check on Pirate just the other day.
Offline barmanjay
« Reply #16 on: December 27, 2007, 12:17:37 AM »
Quote from: "dunl"
damn,.. that kinda sucks
options are seeming kinda slim now
edit:
ok,.. so I did some more searching and found in 84-86,.. the cherokee's used a gm v6 (the 2.8,.. which is still the same block as the newer grand am's 3400 engine [200hp] - just aluminum instead of cast iron) with the ax5 tranny.
Here's a q for you guru's,.. is the bellhousing the same between the 2.5 I4 and the 2.8 v6?
edit again:
ok i did some more searching
got this off another 4x4 forum
Quote
The 2.5L in front of your AX-5 uses a GM 60 degree V6 bellhousing pattern, not the GM 90 degree pattern that the GM "Iron Duke" 4cyl used in CJ's uses, as long as you used a bellhousing from a late CJ with the AMC 4cyl I "think" you'd be okay, or you can get a bellhousing from a 2.8 V6 S-10 with a T-5 and modify/drill the bellhousing to fit the T-18
So the end my engine search if I can't find a replacement 2.5 I4,.. i will drop in a 3.1 or 3100/3400 if I can find.
The cavalier engine harness should be an easy swap (91-94 ign plugs on the column [blue and black] i noticed are exactly the same,.. infact i think they might be the same column)
at least i can get the engine running with a cavalier ecu
[/off topic]
[resume topic]
are the front grilles swappable between?
not that i don't like the square headlights,.. maybe there are better upgrades possible?
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline barmanjay
Re: Swappability between YJ and TJ
« Reply #17 on: December 28, 2007, 09:19:19 PM »
So this is what I'm getting so far
                  YJ    <--->   TJ
         Tailgate   <--->   Tailgate
Rear Bumper  <--->  Rear bumper
        Rear seat  <--->  Rear seat
               Doors  <---> doors (need to swap strikers?)
           Soft top  <---I  (with mods)
          Hard top  I--->  (with mods)
Anything else?
fenders?
front windscreen?
grill?
Jason Kim
Realtor
889-4747
www.jaykim.ca
Trouble Maker
« Reply #18 on: December 29, 2007, 12:08:30 AM »
Another off topic q?
does the 4.0 bolt up to the 2.5 tranny?
If it does it probably wouldn't last long since you hear of people breaking them with the 4 banger.
