Author Topic: Swappability between YJ and TJ  (Read 2755 times)
Offline barmanjay
« on: December 23, 2007, 10:15:15 PM »
I am completely a newbie with jeeps,.. but I do know 95 was the last year for the YJ and 97 was the first year for the TJ
Lots of little changes were made, like the fuel filling spout, front suspension, interior and etc.
What parts can be swapped without hassle?
bumpers?
front suspension?
interiors?
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline Mudhawg
  • Rig Life
Re: Swappability between YJ and TJ
« Reply #1 on: December 24, 2007, 01:46:19 AM »
Quote from: "barmanjay"
bumpers?
front suspension?
interiors?
Jay in the YJ theres leafs were as the TJ has a coil spring suspension reallistically you could convery a YJ to TJ suspension but thats alot of work with coil buckets/control arms not sure bout the rest
Offline LanceM
    • http://community.webshots.com/user/lancemacwilliam
« Reply #2 on: December 24, 2007, 07:14:36 AM »
Almost sure that the rear tailgate is the only thing they kept the same for body wise.
If it ain't broke, it ain't mine.
« Reply #3 on: December 24, 2007, 09:34:49 AM »
bumpers?
front suspension?
interiors?
Bumper - front no (different frame width) Rear yes
Suspension - basically no unless you are a fabricator
Interiors - not a lot.  I believe the seats can be changed but they are not a direct swap
Most of the interchangeability is in the drivetrain and driveline.  The engines, transmissions (except for later models), and t-cases are all the same and basically swap back and forth.  Now axles shafts for the most part can be swapped between the two.  That is about it for direct swap, but if you are willing to use a little imagination and have the tools anything can be done
Offline barmanjay
« Reply #4 on: December 24, 2007, 10:12:59 AM »
so at least the rear bumper can be swapped LOL
wow,.. they look alot alike,.. but yet not much can be swapped betweeen each other.
How about a newer 2.5 I4?
Jason Kim
Realtor
889-4747
www.jaykim.ca
« Reply #5 on: December 24, 2007, 02:17:50 PM »
The blocks for the 2.5L have not changed.  The intakes and exhausts manifold have due to the different fuel delivery and most of the accessory stuff swaps over.
90YJGIMP
« Reply #6 on: December 24, 2007, 04:28:48 PM »
Last issue i have of JP magazine. They found the doors switched over between the YJ and TJ.
Offline AV.NINE
« Reply #7 on: December 24, 2007, 04:40:48 PM »
Quote from: "90YJGIMP"
Wow, that wouldve been the nicest mod on my old yj...
« Reply #8 on: December 24, 2007, 09:56:07 PM »
I don't understand that one because the tilt of the windshields are different
Offline barmanjay
« Reply #9 on: December 25, 2007, 12:31:56 AM »
So does that mean the hard tops dont swap either?
Also:
What motors will esentially "bolt" up to the current tranny
are the trannies jeep specific? or does other chrysler motors bolt up?
(I did use a search and didn't find what I was looking for)
I'm not even 100% sure what tranny the 5sp is on a 95 YJ 2.5 I4
I don't want to give up on gas mileage,.. i hear rumours of fuel hitting $1.50 this summer
Jason Kim
Realtor
889-4747
www.jaykim.ca
« Reply #10 on: December 25, 2007, 02:13:47 AM »
Do a search on google using wikipedia and the jeep model you are looking for....for you, "Wrangler" should produce what you need:
http://en.wikipedia.org/wiki/Jeep_Wrangler
They actually give a fairly good listing of the specs for each model, although there are sometimes mistakes.
2.5, 4cyl, I4:  the tranny you are looking at is the AX5. :)
Merry Christmas
90YJGIMP
« Reply #11 on: December 25, 2007, 11:00:58 AM »
JP magazine was surprised the doors fit to. They were adapting a TJ soft top to fit a YJ. They made it work, but required parts from both a YJ and a TJ soft top to do it. They tested the doors out and found the slope was on the front of the windshield and not the doors themselves.
Offline barmanjay
« Reply #12 on: December 25, 2007, 12:12:11 PM »
Wow,.. cool info,.. I did a search for that ax5 tranny,.. and I see the gm 2.8 bolts up,.. that's crazy!
Jason Kim
Realtor
889-4747
www.jaykim.ca
Offline cuzican
« Reply #13 on: December 25, 2007, 12:54:12 PM »
I previously test fit my YJ doors onto my TJ and my recollection is the only issue was the door striker. The latching mechanisms are different - but you could probably adapt the YJ striker to the TJ. Apparently the YJ hard top will fit with some minor modification to the top of the TJ windshield frame.
Offline barmanjay
« Reply #14 on: December 26, 2007, 10:51:20 AM »
Another off topic q?
does the 4.0 bolt up to the 2.5 tranny?
Jason Kim
Realtor
889-4747
www.jaykim.ca
