Author Topic: 36-37" Tires, what gearing is right?  (Read 2220 times)
Offline AV.NINE
« on: January 13, 2008, 11:26:10 PM »
Just curious, Im running 36"s (on my 99 tj) now and my 5th gear is absolutly useless. I have 4.10's in it right now.
I cant decide what size tires i want to run, but if anyone runs 36's or 37's on their TJ, what gears do you have? and how well does your 5th gear hold up on the highway?
Tribal Jeep
Re: 36-37" Tires, what gearing is right?
« Reply #1 on: January 14, 2008, 12:00:31 AM »
Here is a gear table, although I dont know much about the ratio's and how 5th gear will be affected..
http://www.4lo.com/calc/geartable.htm
just posted this as well to Immortals question.
**even with 31's my fifth gear is useless. designed more for Saskatchewan drivers im thinkin.
« Last Edit: January 14, 2008, 12:23:40 AM by Tribal Jeep »
Offline calltrex
« Reply #2 on: January 14, 2008, 12:02:07 AM »
5.13 for sure
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
« Reply #3 on: January 14, 2008, 07:15:38 AM »
At least 4.88s
Offline AV.NINE
« Reply #4 on: January 14, 2008, 08:16:37 AM »
5.13 for sure
Your on 37's? is that what your running?
Tom, you must have some input here? I think your running 5.13's, how does your 5th hold up?
« Last Edit: January 14, 2008, 08:22:33 AM by AV9Inch »
Offline calltrex
« Reply #5 on: January 14, 2008, 09:16:55 AM »
ya i got 37 iroks
........___________
.../""""/........J
Offline AV.NINE
« Reply #6 on: January 14, 2008, 09:22:14 AM »
ya i got 37 iroks
5th gear is fine for you on the highway?
« Reply #7 on: January 14, 2008, 10:41:52 AM »
He has an auto
« Reply #8 on: January 14, 2008, 12:12:35 PM »
i have 5.13 and 5 speed.
5th gear works well on the highway 8)
« Reply #9 on: January 14, 2008, 11:43:10 PM »
5.38s, auto, 36" IROKS, gets into OD fine but I would go lower if I could. Then again my '89 4.0 probably doesn't have as much umph as you newer TJ guys.
Offline cablesmurf
  • Relapsed Jeep Addict
« Reply #10 on: January 15, 2008, 11:24:38 AM »
I'm running 4:56's w/ 31's (auto)...so in relation, I woud say minimum 4:88's with a 5 Speed or 5:13's with an auto.
Offline Joel
  • Super Uber Web Wheeler
« Reply #11 on: January 15, 2008, 11:41:26 AM »
Go with the lowest gear you can find (5.13) and be done with it...don't be like me who did it twice (4.88->5.13) cause it was so much fun swapping out gears.  :'(
« Reply #12 on: January 15, 2008, 12:37:43 PM »
If you still have a D30 front you will be limited to 4.88s
Offline AV.NINE
« Reply #13 on: January 15, 2008, 12:44:19 PM »
still on the hunt for rubi 44's. I have 2 sets lined up. Just gotta choose which ones. But I think the 1 has 4.88's and the other has 5.13's.
Tribal Jeep
« Reply #14 on: January 15, 2008, 01:39:09 PM »
let me know which one you dont get as i may be interested in picking up the later..
