Author Topic: re-inflating tires in the bush  (Read 1801 times)
jenny
« on: April 20, 2008, 04:06:29 PM »
Thanks to the folks who answered my tire pressure question.  Great comments.  The next question is regarding re-inflation before hitting the highway home.  What do you use? Portable 12v electric air pump? What have you seen or used that works best? Any one have experience with the CO2 cylinders ?
- Mark
Offline calltrex
Re: re-inflating tires in the bush
« Reply #1 on: April 20, 2008, 05:17:17 PM »
why is your name jenny?  Mark
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Offline AMCJeep
« Reply #2 on: April 20, 2008, 05:42:17 PM »
Maybe it's the name of his Jeep? :o
03 Ram 2500 QC, LB, 5.9 CTD
HeadHunter
« Reply #3 on: April 20, 2008, 09:48:13 PM »
I just use one I bought from Napa for $15. plugs into the cigarette lighter. Takes awhile but it works fine.
« Reply #4 on: April 20, 2008, 10:10:16 PM »
the cheap ones from crappy tire and wally mart work, but are slow, and can be un-reliable. look at the units from Viair. i think a lot of folks use their electric pumps and enjoy them. a good viair goes for a couple hundred bucks, but can pump your 35" from 10psi to 30psi in a few minutes i bet.
ask around about the viair.
Offline JohnB
« Reply #5 on: April 20, 2008, 11:02:42 PM »
The best bang for the buck for an electric is the Viair 400C, http://www.viaircorp.com/400c.html
    Begin/End PSI     31" X 10.5"
     0 To 30 PSI    2 Min. 28 Sec.
     15 To 30 PSI    1 Min. 25 Sec.
     Begin/End PSI    33" X 12.5"
     0 To 30 PSI    4 Min. 00 Sec.
     15 To 30 PSI    2 Min. 00 Sec.
     Begin/End PSI    35" X 12.5"
     0 To 30 PSI    4 Min. 50 Sec.
     15 To 30 PSI    2 Min. 20 Sec.
Depending on your vehicle and fabrication skills, an engine driven compressor may be able to done cheaply and they can do 15 to 30 psi is 20 seconds. 8)
Offline cablesmurf
  • Relapsed Jeep Addict
« Reply #6 on: April 21, 2008, 09:59:08 AM »
I use this for $30 from the wreckers...
Cadillac air compressor:
These came in caddy's LTC's, and pretty muchanything with air ride. Go to PYP and you'll find at least a dozen of them
« Reply #7 on: April 21, 2008, 03:35:48 PM »
Crappy tire to start until you really think you need serious air.
Engine driven is not very practical on a TJ. The serpentine system creates a lot of headaches. Its not the same thing as throwing together a v belted system.
Viar, extreme air, and several others are good electric systems, but shouldnt be considered until you really think you need considerable air.
Jeeps being as small as they are, you dont need any more then 18psi to safely and comfortably drive yourself home, or to a gas station after wheeling. Without beadlocks you probably arent wheeling with less then 12psi.
6 psi a tire is pretty insignificant, even for a crappy tire compressor.
The caddy ones are cheap and reliable, but really arent much faster then a crappy tire unit in my experience.
Offline Darklen
« Reply #8 on: April 21, 2008, 06:52:17 PM »
Since I have access to the equipment, I'm going to be running air from a high pressure air cylinder. I have a 4500psi carbon fiber SCBA cylinder (88cu.ft volume, plenty for trail use) with a bracket and a high pressure regulator with hoses. I just have to figure out where and how I want it mounted and assemble couplings so I can use air tools if needed.
« Reply #9 on: April 21, 2008, 07:25:16 PM »
think im gonna buy a Warn powerplant.
Offline Waytec
  • not all there
« Reply #10 on: April 22, 2008, 05:52:55 PM »
I would love to have a Power plant one day maybe.
I got a 12v air compressor from Modern. Same as a Viair but cheaper. I finger it is good enough for now. I have other places I need to spend the money first.
The obstacle is the path.
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #11 on: April 22, 2008, 06:16:14 PM »
Starting fluid and a lighter? lol
84 Mustang GT-Built 351W 5spd
Offline Fredduck
  • RIDE ON
« Reply #12 on: April 22, 2008, 07:13:16 PM »
I concur ;) ;) ;) Light em up
Mr-B
« Reply #13 on: April 23, 2008, 10:14:53 PM »
I use ether(starting fliud in a spray can) and a torch on my semi tires often....thats a fast bead seat but then theres the issus of airing up... ;D :o 8)
Offline dubbleJs
« Reply #14 on: April 23, 2008, 10:53:21 PM »
lol ya thats what I was thinking...isnt this thread about airing up not popped beads...? :D
