Author Topic: Q: Oil pressure sending unit  (Read 3593 times)
Offline redbull
« on: September 23, 2005, 12:07:44 AM »
I'm replacing mine tomorrow. I'd like to know if this can be done without draining the engine oil? Thanks.
weekendwarrior
« Reply #1 on: September 23, 2005, 12:19:57 PM »
Ive wondered that too. Mine seems to work some times but not other. Usually doesn't work after an oil change. If you don't find out before you remove it let me know if you get covered in oil :(
henry
« Reply #2 on: September 23, 2005, 12:27:04 PM »
How high up on the block is the sending unit?  The worst that can happen is it will drip on to the floor, you won't get covered in oil.  The oil is not under any pressure, so gravity is the only thing to worry about, but I think there won't be much oil come out at all.
Darren :twisted:
Offline redbull
« Reply #3 on: September 23, 2005, 03:52:13 PM »
Sending unit is right above the oil filter. Pulled off the old one and not so much as a drip came out. Screwed in the new unit (paid $40) and I have a working oil gauge again. No more pegged gauge even with the motor off!
RedYJ
« Reply #4 on: September 23, 2005, 10:11:17 PM »
Sounds pretty easy, always wanted to fix mine.  Where did you pick up the new sensor?
Offline redbull
« Reply #5 on: September 23, 2005, 10:50:44 PM »
Quote from: "RedYJ"
Big S Auto in Strathmore, but any auto parts store should be able to help you out.
Next on my list is the temp gauge.
Offline Big_Jeep
Re: Q: Oil pressure sending unit
« Reply #6 on: July 26, 2010, 02:20:20 PM »
This seems like the best one to raise from the dead....
On Saturday night my Jeep started to sputter and the oil pressure was dropping. Hopped in this morning and it did the same thing and now the check engine light came on. No leaks and all fluids are topped up and as the should be. Could it be something as simple as the OPSU?
I was Jeepless since 2006. So I had to make a tough decision; the wife, or get a Jeep. So glad to be a Jeep owner again! I still miss my FSJ the most
« Reply #7 on: July 26, 2010, 03:28:43 PM »
Im going to ask the obvious but which code was tripped?  That will probably help you in narrowing it down
Offline Big_Jeep
« Reply #8 on: July 26, 2010, 04:24:25 PM »
I cant get the diagnostic codes to trip(on-off-on-off-on). Not sure if it has something to do with the after market ignition imobilizer the previous owner installed
Offline The Machinist
  • I’m with stupid!
« Reply #9 on: July 26, 2010, 06:38:54 PM »
Doesn't sound like an OPSU problem.  If your engine is sputtering at idle and all most stalling your oil pressure could be going low.  When my OPSU bit the dust it did not affect the way the engine ran.  Best way to tell is to put a mechanical guage on there.
Offline dontask
« Reply #10 on: July 26, 2010, 08:33:41 PM »
40$ is a steal, I priced one out at napa and it was 75.00.
Might be worth the drive out to strathmore
Offline Big_Jeep
« Reply #11 on: July 26, 2010, 08:57:47 PM »
Well call first....I'm sure the price has went up in five years ;D
No sputtering while the Jeep is idling, just when accelerating(and not always). Runs fine and sounds normal
Offline esi
« Reply #12 on: July 26, 2010, 09:00:11 PM »
If you head to Strathmore talk to Dave or Tyrone at Big S
Formerly of Boots & Boost Inc
« Reply #13 on: July 26, 2010, 09:26:42 PM »
mine sputters when the map sensor acts up.  if the jeep drops to 2-300 rpm when sputtering like mine then the oil pressure will drop as well.  if the oil drops enough my check guages lights up with a beep but this only happened when running a fram oil filter.
« Reply #14 on: July 27, 2010, 07:37:38 AM »
What is the condition of the distributor cap?  I have a sputtering problem when my distributor cap was fouled.
