Author Topic: Champion winches(which mounting plate for TJ)  (Read 957 times)
Offline RACKMAN
« on: May 17, 2008, 04:35:22 PM »
My brother bought a Champion winch from Costco and it only came with a cradle mount, so I was wondering what winch plates will work for mounting on a TJ? Will a Warn plate work for these winches? Thanks.
RACKMAN
Re: Champion winches(which mounting plate for TJ)
« Reply #1 on: May 17, 2008, 04:40:43 PM »
Yeah, they are the same bolt pattern.
Offline RACKMAN
« Reply #2 on: May 17, 2008, 10:11:54 PM »
Thanks Bnine.
RACKMAN
shibby
« Reply #3 on: May 27, 2008, 10:16:28 AM »
If you're looking for a winch plate for a jeep, Champion also offers these if you call them directley. They are less expensive than the warn plates. But they may be made of slightly lower guage steel plate.
HeadHunter
« Reply #4 on: May 27, 2008, 06:13:07 PM »
or you could drill some holes in the plate they gave him.
Offline RACKMAN
« Reply #5 on: May 28, 2008, 08:54:36 AM »
No...you can't...as stated, the winch only came with a cradle mount for use in a reciever hitch.
RACKMAN
austin
« Reply #6 on: June 02, 2008, 09:00:35 AM »
I just installed mine this weekend and used the cradle mount ( modified of course).  I cut the receiver hitch off and notched the plate to fit over my bumper. Removed the handles and welded it on. I can still remove the winch if I need.
