Author Topic: Front U-Joints  (Read 1855 times)
Offline Waytec
  • not all there
Front U-Joints
« on: June 20, 2008, 10:16:14 PM »
What is involved in changing the u-joints on the front axel shafts on a 95 Cherokee?
I dos not look like fun.
The obstacle is the path.
Offline calltrex
Re: Front U-Joints
« Reply #1 on: June 20, 2008, 10:45:13 PM »
take all brakes off
take  unit bearing and axle out
take bearing off
then change u joint
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Re: Front U-Joints
« Reply #2 on: June 21, 2008, 10:51:44 AM »
It is pretty simple and it just the getting the unit bearing off can be tough if it has never been changed.  I recommend loosening the axle hub nut first while the tire is still on because it is torqued to 175 lbs-ft.  The hub nut is 36 mm and if you need one let me know
TIP ANTISEIZE all mating surface when you are putting it all back together.  It definitely helps big time in the future
Offline dubbleJs
Re: Front U-Joints
« Reply #3 on: June 21, 2008, 10:22:41 PM »
Yup its a fairly straight forward job but the hub can be tough to get off sometimes. Spray lots of PB or wd40 around it, back the 3 12pt bolts out a little bit and with a socket still on the bolt head give it a few wacks with a hammer. That should usually pop it forward. If that doesnt work, get a hub puller or throw an old rim on there and hit it from behind with a mallet....   8)
Offline rws
  • Stump Grinder
Re: Front U-Joints
« Reply #4 on: June 22, 2008, 05:35:27 PM »
I usually undo where the tie rod is attached to the steering knuckle which gives you more room to maneuver when you whack the the socket mentioned in the previous thread.  I also use a 480z BFH.
Re: Front U-Joints
« Reply #5 on: June 22, 2008, 07:52:13 PM »
it is possible to change the u-joint without removing the unit bearing... yes, it is a little more difficult, but it saves the hassle of removing the big nut of the axle end and having to re-torque it after. not everyone has the 36mm socket, nor a torque wrench... ok, even the 12-point 13mm socket isnt easy to come by. just a thought.
Offline XJHERO
  • Soberphobic
Re: Front U-Joints
« Reply #6 on: June 22, 2008, 08:46:22 PM »
:o
Wow id like to see sumone do that! It would be impressive
DD
Get at me Wolf
Offline dubbleJs
Re: Front U-Joints
« Reply #7 on: June 22, 2008, 10:56:37 PM »
I found my 12pt 13mm at home depot...took a bit of searching!
Offline Waytec
  • not all there
Re: Front U-Joints
« Reply #8 on: June 22, 2008, 11:07:01 PM »
Thanks everyone I will be diving into this thing shortly. As for tools and BFH’s I am a heavy equipment mechanic to so getting a big torque wrench is not an issue, but thanks for the info everyone. I will soaking it in PB starting tomorrow and buy the time I get to changing them they will come out with some ease.
Offline calltrex
Re: Front U-Joints
« Reply #9 on: June 23, 2008, 08:12:05 AM »
I just use a impact to get the nut off..
........___________
.../""""/........J
Re: Front U-Joints
« Reply #10 on: June 23, 2008, 06:45:28 PM »
I use the spicer snap-tite u-joints exculsivly and after 4years I have to replace the first one.  Cheapest I found was $37/each at DSI. This was for a D44 axleshaft. Just picked them up today.
Rubber Boots
Re: Front U-Joints
« Reply #11 on: June 24, 2008, 06:24:31 AM »
I found the best way to get the bearing assembly of is to hammer against the bolt holes on the outer portion causing the whole unit to start to rotate.  A couple of good whacks and it usually pops free.  I have done both bearings now twice and never used any antisieze when reassembling.  The first time I did them I tried hammering them from behind and managed to bang up the dust shield pretty good.  Good luck and it should be a fairly easy job.  I changed both sides  in about an hour in my drive way two weeks ago.
« Last Edit: June 24, 2008, 07:50:01 PM by Rubber Boots »
