Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
zippers on soft-top
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: zippers on soft-top (Read 1410 times)
scott/kerri
Budget Lift
zippers on soft-top
on:
July 21, 2008, 09:15:23 PM »
does anyone have any thoughts on how to make the zippers on soft-tops slide easier......havin major issues with mine they keep missing teeth and is a chore and a half to do up...
Logged
Scott has the 04 tj...nickname itty bitty
Kerri has the 09 jk , 4 inch lift
Tinkerer
UberWheeler
Re: zippers on soft-top
Reply #1 on:
July 21, 2008, 09:19:25 PM »
Chrysler/Jeep makes a zipper lube for them... don't know how well it works tho. I've used candlewax, which works reasonably well and hasn't damaged anything in the past.
Logged
LT285/75R15 Trxus MT's
VE6PDB - usually on VE6RYC
mudninja
Guest
Reply #2 on:
July 21, 2008, 09:21:10 PM »
i have the same problem. all i could come up with is vice grips and force
Logged
RUBI
Guest
Reply #3 on:
July 21, 2008, 09:32:13 PM »
Clean em good, then lube with Silicone spray.....also really good for weather stripping around doors and windows. Keeps them soft and pliable!!!
Nice TIGHT Seal !!!
Not for other uses ...........
Logged
BEZZ
Budget Lift
Reply #4 on:
July 21, 2008, 10:10:34 PM »
I'm gonna beat Nick to the punch and reccomend Jigaloo!!!!!
"Jig-A-Loo, an invisible silicone-based lubricant and water-repellent that doesnt stain or stink. It stops squeaks, lubricates, loosens and prevents rust"
Super cheap and it works!
Logged
Buy some safety glasses.
You can jackoff with a fake hand but you cant see out of a glass eye.
Gearhead
Talks waaay too much!
Reply #5 on:
July 21, 2008, 11:05:54 PM »
Mopar soft top zipper cleaner & lubricant . 2 fluid ounce applicator part # 05066440aa
Logged
FiEND
Wrecking Ball
Reply #6 on:
July 22, 2008, 01:49:58 AM »
i tried a bar of soap, worked good, didnt last.
i tried white lithium grease, worked good, then summer was over.
Logged
scott/kerri
Budget Lift
Reply #7 on:
July 22, 2008, 06:57:21 PM »
thank you for all the input......but have to fix first now..scott went crazy with the pliers and well now have to figure out how to unzip from wrong end so can try to sip again hee hee
Logged
Evil-Jeep
UberWheeler
Reply #8 on:
July 24, 2008, 02:55:12 PM »
For a real quick/cheap fix, spray the zips with PAM cooking spray. works unbelievably well.
Logged
yjcanibul
Guest
Reply #9 on:
July 24, 2008, 07:03:45 PM »
I use liquid dish soap , liberal amounts - let set - then wipe
them clean with a rag and lube again ... should slide freely
when they start to stick again ( they will ) then redo ...
I've actually seen bubbles if caught in a storm after doing
Last Edit: July 24, 2008, 07:21:07 PM by yjcanibul
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
zippers on soft-top
