Author Topic: zippers on soft-top  (Read 1414 times)
Offline scott/kerri
zippers on soft-top
« on: July 21, 2008, 09:15:23 PM »
does anyone have any thoughts on how to make the zippers on soft-tops slide easier......havin major issues with mine they keep missing teeth and is a chore and a half to do up...
Scott has the 04 tj...nickname itty bitty
Kerri has the 09 jk , 4 inch lift
Offline Tinkerer
    • My (OLD OLD OLD) website
Re: zippers on soft-top
« Reply #1 on: July 21, 2008, 09:19:25 PM »
Chrysler/Jeep makes a zipper lube for them... don't know how well it works tho.  I've used candlewax, which works reasonably well and hasn't damaged anything in the past.
2004 TJ Rubicon 2.5" Cage Puck Lift
LT285/75R15 Trxus MT's
ARB Bullbar and Warn XD9000i winch
Garvin Wilderness Swingaway Rack
Cobra 75WXST CB, Yaesu FT8900 Ham
VE6PDB - usually on VE6RYC
mudninja
« Reply #2 on: July 21, 2008, 09:21:10 PM »
i have the same problem. all i could come up with is vice grips and force :)
RUBI
« Reply #3 on: July 21, 2008, 09:32:13 PM »
Clean em good, then lube with Silicone spray.....also really good for weather stripping around doors and windows. Keeps them soft and pliable!!!
Nice TIGHT Seal !!!  ;) Not for other uses ........... :-[
Offline BEZZ
« Reply #4 on: July 21, 2008, 10:10:34 PM »
I'm gonna beat Nick to the punch and reccomend Jigaloo!!!!!
"Jig-A-Loo, an invisible silicone-based lubricant and water-repellent that doesnt stain or stink. It stops squeaks, lubricates, loosens and prevents rust"
Super cheap and it works!
Buy some safety glasses.
You can jackoff with a fake hand but you cant see out of a glass eye.
Offline Gearhead
« Reply #5 on: July 21, 2008, 11:05:54 PM »
Mopar soft top zipper cleaner & lubricant . 2 fluid ounce applicator    part # 05066440aa
Offline FiEND
  • Wrecking Ball
« Reply #6 on: July 22, 2008, 01:49:58 AM »
i tried a bar of soap, worked good, didnt last.
i tried white lithium grease, worked good, then summer was over.
1Wide2High
ILV2FRT
'97 TJ [sold]
'17 JK Rubicon
Offline scott/kerri
« Reply #7 on: July 22, 2008, 06:57:21 PM »
thank you for all the input......but have to fix first now..scott went crazy with the pliers and well now have to figure out how to unzip from wrong end so can try to sip again hee hee :-[
Offline Evil-Jeep
« Reply #8 on: July 24, 2008, 02:55:12 PM »
For a real quick/cheap fix, spray the zips with PAM cooking spray. works unbelievably well.
“I contend that we are both atheists. I just believe in one fewer god than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours.”
yjcanibul
« Reply #9 on: July 24, 2008, 07:03:45 PM »
I use liquid dish soap , liberal amounts - let set - then wipe
them clean with a rag and lube again ... should slide freely
when they start to stick again ( they will ) then redo ...
I've actually seen bubbles if caught in a storm after doing  ;)
« Last Edit: July 24, 2008, 07:21:07 PM by yjcanibul »
