Author Topic: cb - receive ok but cant send - tune ?  (Read 2755 times)
yjcanibul
« on: August 25, 2008, 10:25:19 PM »
my cb quit transmitting ,  it just sends garble (ch 10 anyway) - receives nice and clear - my antenna is a 50ohm magnetic mount,  its a two piece w/adjustable length via set screw which was loose and therefore in the shorter length position ...
can send garble but receive clear be a symptom of antenna out of tune ?
Offline barmanjay
Re: cb - receive ok but cant send - tune ?
« Reply #1 on: August 25, 2008, 10:27:03 PM »
sounds like bad mic
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline Tinkerer
    • My (OLD OLD OLD) website
« Reply #2 on: August 26, 2008, 06:23:06 PM »
We forgot to exchange info :)   I was on the run last Saturday.
Sounds like a mic more than a short, but it was hard to tell in the confusion going on before the run.
LT285/75R15 Trxus MT's
VE6PDB - usually on VE6RYC
yjcanibul
« Reply #3 on: August 26, 2008, 07:00:33 PM »
wonder if I can just buy a mic ... they cant be worth much ...
RUBI
« Reply #4 on: August 26, 2008, 07:12:59 PM »
Yup...head on down to the Road King. Talk to the Old Dude who owns/runs the CB shop...he can fix you up, maybe even find ur problem if it ain't the mic !!  ;)
Offline Tinkerer
« Reply #5 on: August 26, 2008, 07:15:36 PM »
Yeah, Dean is pretty good with CB radios and repairs.
RUBI
« Reply #6 on: August 26, 2008, 07:23:45 PM »
Tink.......what all is involved with the Ham st up and approx cost ?  $$$$$$
 Sorry...... :-[ Didn't mean to jack ur thread YJ !!
« Last Edit: August 26, 2008, 08:07:23 PM by RUBI »
Offline Tinkerer
« Reply #7 on: August 26, 2008, 07:33:21 PM »
Perhaps another thread?  After getting the operators license, the equipment costs vary from not much more than a CB to pretty pricey!  ($1000+ for the radio itself before antennas, wiring etc.)  I can put up some URL's in the new thread.
yjcanibul
« Reply #8 on: August 26, 2008, 08:55:59 PM »
thanks for the tip(s) guys - short/bad mic makes sense ... will drop by the
road king maybe he can save it
not up on ham either ,  last I heard you needed big 30ft antenna etc and
a license ...
« Last Edit: August 26, 2008, 09:03:49 PM by yjcanibul »
Offline Tinkerer
« Reply #9 on: August 26, 2008, 10:04:08 PM »
At least CB's are cheap if that one is busticated!
I created a new thread/post in this area to start a technical Amateur/Ham post.
Offline SmilinVamp
« Reply #10 on: August 27, 2008, 08:53:31 AM »
Is there a power meter on your radio... if it doesn't show increased power (watts) when you push the transmit button, then it's not the mic it's the transmitter....
Offline 01sahara
« Reply #11 on: August 27, 2008, 09:39:08 AM »
In the past I have had the same problem due to a bad ground on the CB and it was grounding out through the antenna.
I the same problem again now garbled sending. As per our club radio expert, my antenna is fine, my mic is fine, my radio is toast. They are cheaper to by a new one than to try to have it fixed. Time for a new CB for me. Borrow someone else's mic and see if that works.  It will tell you if it is the problem or not.
yjcanibul
« Reply #12 on: August 27, 2008, 06:17:24 PM »
no pwr meter,  a little 'Tx' lights when I push the mic in ...
will find another mic and try it,  else the dude at the cb place maybe can help,
since it receives good am thinking mic or mic jack ...
I am same way - aint gonna spend much more than $10 to fix it else its scrap
Offline SmilinVamp
« Reply #13 on: August 27, 2008, 06:20:41 PM »
Mine was a broken solder joint in the TX circuit... but mine has a TX meter and I could see there was no TX power...  your's is sounding like a mic problem though...
