Author Topic: carpets  (Read 1408 times)
Offline lizard230
carpets
« on: May 07, 2010, 12:48:28 PM »
carpets are starting to stink and rot anyone got any suggestions
2000 TJ
Offline 01sahara
Re: carpets
« Reply #1 on: May 07, 2010, 12:51:55 PM »
I took them out and used good quality truckbed liner. Big job but now I can pull the drain plugs and wash it all out.
If you want to keep them take them out and give them and the inside of the jeep a good wash. Let them dry fully before putting them back.
« Last Edit: May 07, 2010, 01:00:05 PM by 01sahara »
Offline Evil-Jeep
Re: carpets
« Reply #2 on: May 07, 2010, 12:59:22 PM »
buy mine....... have had them stored in the basement since I brought the Jeep home
Offline lizard230
Re: carpets
« Reply #3 on: May 07, 2010, 02:54:55 PM »
how much was did it cost to get done or did u do it your self
2000 TJ
Offline 01sahara
Re: carpets
« Reply #4 on: May 07, 2010, 03:07:39 PM »
Did it my self. Takes a day or so to prep the surface for a good job. Material can run from $50-$200 depends on the quality of bedliner.
Offline lizard230
Re: carpets
« Reply #5 on: May 07, 2010, 03:22:00 PM »
was it hard to do any special tool needed
2000 TJ
Offline RckyMtnTJ
    • http://www3.telus.net/lck
Re: carpets
« Reply #6 on: May 07, 2010, 03:40:26 PM »
Remove all interior, scuff all surfaces and remove shine.  I used scotch pads, sandpaper and a wire brush.  Clean really good with xylene, let dry and then either roll in, brush in, or spray in.  I brushed mine in and got pretty good results with Durabak.  If I had it to do over again, I definitely will/would spray it in for more consistent results.
98 TJ 4" lift + goodies
Offline 01sahara
Re: carpets
« Reply #7 on: May 07, 2010, 04:17:16 PM »
I used a product called Raptor. it is one of the higher $ spray on finishes. Prep the surface really well so you know it will stick. If you google Raptor beadliner and jeep there were a few good posts on the us Jeep sites with pics of others doing this to the interior.
Offline lizard230
Re: carpets
« Reply #8 on: May 07, 2010, 06:58:33 PM »
ok so the carpets are out and i have ALOT of rust on the floor underneath my gas peddle on both drivers and passenger floors what are some options before i spray it
2000 TJ
Re: carpets
« Reply #9 on: May 07, 2010, 09:36:45 PM »
drill and wire wheel.  wax on wax off.
