Author Topic: harmonic balancner issues  (Read 1580 times)
« on: November 17, 2010, 10:21:13 AM »
the crank pulley/harmonic balancer on the jeep doesn't look to happy on my newly acquired ZJ.  its wobbling something fierce.  i noticed it today after the jeep wouldn't start........ i finally got it going but it was making one hell of a racket.  looked at the drive pulleys and the crank pulley is wobbling something fierce. (so is another freespooling pully)  i have a feeling this is my vibration problem as well.
is it fixable or should i just start pulling this engine out?
cheers
Offline CatSplat
Re: harmonic balancner issues
« Reply #1 on: November 17, 2010, 12:15:28 PM »
Is the actual pulley wobbling, or just the balancer part?
Jeep of Theseus
« Reply #2 on: November 17, 2010, 12:27:56 PM »
are all the bolt in and are they all tight
might want to check that
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #3 on: November 17, 2010, 07:29:48 PM »
just check and replace the balancer if necessary.
84 Mustang GT-Built 351W 5spd
« Reply #4 on: November 17, 2010, 08:13:53 PM »
IS it a 4.0L? They used a 2 piece dampener, an inner ring and outer ring with a rubber band between the two. Sometimes the outer ring will start to walk off or it will spit out the rubber band. Replacement at that point is usually necessary but a used one can be used if it visually looks good.
« Reply #5 on: November 17, 2010, 11:17:19 PM »
thanks guys,
and ya clay, that sounds like whats happening pretty much.  PITA to change?  just a regular 3 pronged puller should be good to pull it right?   looks like i have to pull the rad too...........
gonna do it this weekend ;)
Offline The Machinist
  • I’m with stupid!
« Reply #6 on: November 17, 2010, 11:37:06 PM »
Easy to change, use a harmonic balancer puller.  Three bolts that screw in to it, a 3 jaw will probably just break parts off.  PA sells them cheap, or I have a spare one you can borrow if you feel like driving to coventry hills.
Offline Gearhead
« Reply #7 on: November 18, 2010, 07:54:52 AM »
Do not pound the replacement on with a hammer  !
Offline Pookapotamus
« Reply #8 on: November 18, 2010, 08:01:34 AM »
is it not about time you sold this johnny? or have you not put enough mony into it to justify selling it??
 :P
« Reply #9 on: November 18, 2010, 09:26:04 AM »
thanks jamey. PA will do ;)
pook this one ain't really worth selling :)  when it dies, i'll either fix it or strip it for parts ;)
« Reply #10 on: November 18, 2010, 09:36:43 AM »
dont lie, its on kijiji allready isint it!
« Reply #11 on: November 18, 2010, 09:39:11 AM »
thats it pook. you're comin over to help me fix it ;)
Offline Knox
« Reply #12 on: November 18, 2010, 09:51:51 AM »
If you want another beer drinking supervisor give me a shout I'm around this weekend. that way you know Pook doesn't have to watch you all the time, he can take a nap or 2
2003 TJ
« Reply #13 on: November 18, 2010, 11:31:15 AM »
bring it to my place we can test my plama on it and fix it real good!  8)
Offline mike s
  • Good times!
« Reply #14 on: November 18, 2010, 06:55:49 PM »
Let me know if you guys need a hand. Some run-out on balancer is okay, not a 8 600RPM race engine....right? If you can't fit the puller in with the rad in place, you can sometimes walk the balancer off with a couple of pry bars
oldEnuff2NObetter
but still can't help myself
