Author Topic: Best rust/penetrating oil?  (Read 4996 times)
Offline BUKI
  • Project Fugly
« on: April 17, 2012, 09:20:19 AM »
What's the best one?? Want to adjust steering stops but crazy rust, also going to heat the crap out of them. Any suggestions? :)
Offline NUXJR
Re: Best rust/penetrating oil?
« Reply #1 on: April 17, 2012, 09:34:12 AM »
I've been using Release-All for a long time.  Seems to work quite well and it's more bio friendly too
« Reply #2 on: April 17, 2012, 11:01:26 AM »
50/50 mix of auto tranny fluid and acetone was rated better than any off the shelf product.
Vince
Offline Jrama
« Reply #3 on: April 17, 2012, 11:02:39 AM »
^^I have never known a penetrating oil to ever really solve issues, they just make the doable easier. Off the shelf PB blaster is my favorite but I'm definitely going to give the tranny fluid and acetone a try...luckily not a lot of rust or stuck bolts on my 04  ;D
I should add the most useless one i tried was liquid wrench, but its not like I have an objective method of proving which oils are better
« Last Edit: April 17, 2012, 11:08:38 AM by Jrama »
Offline IgniteTJ
« Reply #4 on: April 17, 2012, 11:06:11 AM »
I like sea foam or wurth products personally
Offline Knox
« Reply #5 on: April 17, 2012, 11:15:11 AM »
for off the shelf products, I've had good luck with both PB blaster and Liquid Wrench.
I actually prefer Liquid Wrench since it's non toxic/wont catch fire, so you can heat and spray at the same time all you want.
2003 TJ
Offline BUKI
  • Project Fugly
« Reply #6 on: April 17, 2012, 01:04:15 PM »
Vince
I'm gonna try this as I have both. I'm assuming you just brush it on??
Offline Knox
« Reply #7 on: April 17, 2012, 01:40:20 PM »
old style squeeze ketchup bottle?  ;D
2003 TJ
« Reply #8 on: April 17, 2012, 04:31:38 PM »
I've never tried it but will mix it and use a refillable WD40 spray bottle to apply it.
Vince
Offline LukeDuke
« Reply #9 on: April 17, 2012, 04:56:35 PM »
Heat it up with a torch. Take one of your wifes/girlfreinds/roommates fancy candles and melt it all over the threads. Spin out by hand.
We use this trick on rusted heavy equipment under caraige all the time.
RDJP President
http://www.reddeerjeep.com/
Offline Black Betty
« Reply #10 on: April 19, 2012, 10:12:16 PM »
X2, both awesome products.
Stupid hurts
« Reply #11 on: April 20, 2012, 11:03:17 AM »
WD 40 is the best one i've ever used.
i've never met a bolt i couldn't get out using WD 40...........
Offline Black Betty
« Reply #12 on: April 20, 2012, 06:19:58 PM »
Hmm, I have not had such luck with good old wd.  Its actually Water Dispacement (trial #40).  But for cleaning up old metal it works great.
Stupid hurts
« Reply #13 on: April 21, 2012, 12:44:22 AM »
i've heard many people have not had success with WD40. i've never had a problem with it.  i would like to attribute it to the qualities of said product, but its most likely due to my massive muscles, and ability to input such forces to said bolt via ratchet.
all though air tools are nice............................. ;)
Offline BUKI
  • Project Fugly
« Reply #14 on: April 21, 2012, 11:06:08 AM »
No no. You just use your used car salesmen techniques to beat it into submission.  ;)
