Author Topic: Speedometer gear?  (Read 3004 times)
Offline Zooguy
  • 83 CJ7- AMC 360
Speedometer gear?
« on: January 28, 2021, 07:10:04 PM »
I have tried to look this one up but couldn’t find any info.
My Jeep has a T5, with 293 gears and 35s.
Is there a speedo gear for this?
Thanks in advance.
Offline Zooguy
  • 83 CJ7- AMC 360
Re: Speedometer gear?
« Reply #1 on: February 14, 2021, 09:02:00 AM »
Anyone want to tell me where I might find that info?. Or what I need to know to figure it out myself? Thanks
« Reply #2 on: February 14, 2021, 10:00:34 AM »
Maybe reach out to Bill Landry down in Lethbridge, he seems to tinker a lot with the CJ platform.
He’s a member on here and his user name is, wait for it....        Bill Landry
« Reply #3 on: February 14, 2021, 01:47:47 PM »
Not sure on the cj’s. You can check omix or crown and see if they any options for your application.
Offline Zooguy
  • 83 CJ7- AMC 360
« Reply #4 on: February 17, 2021, 07:57:07 PM »
Awesome thanks. I will reach out to him. And check those websites out.
Offline Zooguy
  • 83 CJ7- AMC 360
« Reply #5 on: April 22, 2021, 09:09:05 PM »
So I still haven’t figured this out, so I thought I would see if anyone can help.
1983 CJ7 Jeep
T5
4.10 gears
35 inch tires
25 tooth speedometer gear
My speedo says between 120-125km when my phone speedo says 100km
I have looked at a couple charts and one says I should use a 31 tooth gear and one says 33.
Not sure which is right. Any suggestions would be great.
« Reply #6 on: April 22, 2021, 10:52:40 PM »
Calculate for the proper gear by measuring your tire with a tape measure when it’s mounted on the jeep, don’t go off the size on the tire. I use a gear for a 34” tall tire. Remember the tires wear down too.
Offline MattMan
« Reply #7 on: April 23, 2021, 12:14:49 PM »
And if that doesn’t work… It’s probably easier to just re-calibrate your phone.  8)
MattMan
Offline Zooguy
  • 83 CJ7- AMC 360
« Reply #8 on: April 23, 2021, 06:36:19 PM »
I just measured my tires and who knew, 34 inches. Mickey Thompson lied 🤥
Might be cheaper to just recalibrate my phone 👍
So I’m thinking a 34 tooth now? Sound right?
Any suggestions on where to buy one.
« Last Edit: April 23, 2021, 09:16:47 PM by Zooguy »
Offline Zooguy
  • 83 CJ7- AMC 360
« Reply #9 on: April 26, 2021, 07:29:13 AM »
Looks like I was going the wrong way. I was recommended going to a 21 tooth gear. Which makes sense since I need the speedo to slow down but the charts say to go to anywhere from 31-34.
This Jeep stuff is confusing 😉
Thoughts?
Also where to buy one, I can’t find a 21 tooth yet
« Last Edit: April 26, 2021, 07:32:22 AM by Zooguy »
Offline Zooguy
  • 83 CJ7- AMC 360
« Reply #10 on: April 27, 2021, 07:59:35 AM »
So I think the advice I was given went the wrong way. He said that it is about one tooth per 5 km. So I think it should be a 29 tooth gear. That one I can find. Does that sound right?
« Reply #11 on: April 27, 2021, 09:53:49 AM »
Does omix or crown have gears for yours?
Offline Zooguy
  • 83 CJ7- AMC 360
« Reply #12 on: April 27, 2021, 10:38:04 AM »
Omit does, I couldn’t find it on Crown.
My main issue is what size to get.
I now have been told, and read, from sizes 29-34. I don’t feel like buying these more than once. Hoping to get it narrowed down here.
« Reply #13 on: April 27, 2021, 11:13:49 AM »
Is there not a calculator or graph showing which one to use?
Offline Zooguy
  • 83 CJ7- AMC 360
« Reply #14 on: April 27, 2021, 02:09:22 PM »
There are a few, and they seem to vary. I’m not sure which one is correct.
« Last Edit: April 27, 2021, 02:29:11 PM by Zooguy »
