Author Topic: advice needed  (Read 1777 times)
Offline JasonL_031
    • http://www.cardomain.com/ride/2449290
advice needed
« on: September 18, 2006, 11:02:27 AM »
ok i have a set of 33x12.5R15 and was wondering if they would fit on the stock rims with the stock suspension. would there be any problems with the drivetrain? for a 2003 jeep tj with a inline 6  and 5 spd manual
1994 ZJ
6.5 inch custom lift
5.2L v8 with 5.9 exhaust
35x12.5r15 beadlocks
custom front bumper
98 leather interior
rugged ridge steering conversion
np231 tcase swap
HIDs
LED off road lights
Offline apex
advice needed
« Reply #1 on: September 18, 2006, 02:01:52 PM »
you will want 15x8 rims at minimum. Stocks are likely 15x7. 33's will rub a lot with no lift. Just ask Chris/Elsifer. 3-4" lift recommended. T-case drop or better yet a SYE and a new DS needed to correct driveline angles or else you get wicked vibes. Better start saving up man, its a slippery expensive  slope you are going down.
merlin
advice needed
« Reply #2 on: September 18, 2006, 02:30:46 PM »
the largest tire that i could put on my 04 jeep sport was 31.5x10.5x15r i believe and i had no problems at the trailer clean up in waiparous
Offline 01sahara
Tire size.
« Reply #3 on: September 18, 2006, 02:57:29 PM »
As well as the rubbing issue 33” may be to large of a tire without a gear change. I have 31” with 307 gears and its ok but not great, 5th is not much use without a tail wind. The bigger the tire the higher numeric gears you will want. Ask Greg / Apex what he thinks of 33" tires and 307s.
Offline apex
advice needed
« Reply #4 on: September 18, 2006, 06:10:08 PM »
Oh, and not to forget the brake lines,  yearly hub swaps, fan clutches, steering boxes, pinion seals, driveshafts and ujoints. Besides that insignificant little stuff... you'll be fine. Infact, you should go to 35's because you are going to be running those eventually anyways.
Blair ...What is this talk about 5th gear? Never heard of it, i don't know what you are talking aboot.
Offline JasonL_031
advice needed
« Reply #5 on: September 19, 2006, 01:13:34 AM »
yea thats what i was thinking but i think my clutch is burnt out takes alot more time to engage and she is also really fussy moving forward in first and extreamly fussy moving in reverse i am thinking that it is the cutch disc is burn out and needs a new one what do you guys think? and if so how many of you guys have replaced a clutch in a jeep tj with the 5 spd manual? may correction WILL need help to do it
1994 ZJ
custom front bumper
98 leather interior
np231 tcase swap
HIDs
LED off road lights
Offline apex
advice needed
« Reply #6 on: September 19, 2006, 03:54:02 PM »
judge for yourself...
http://www.4x4xplor.com/clutch.html
I wouldn't try it but there are some talented wrench turners on this site that will.
advice needed
« Reply #7 on: September 19, 2006, 04:11:19 PM »
I do clutches
advice needed
« Reply #8 on: September 20, 2006, 10:02:05 AM »
Your 03 already needs a new clutch, wow.  If you have the 30" tire package you will have 8" rims which will be fine.  Also if that is the case, you will have 3.73 gears which will be okay with 33s.  I know guys on 35s with 3.73.
If you want to fit 33s cheaply, 2" body lift ($150), plus 2" coil spacers and shocks ($300-500), then you will be done.
Also try the search function, because a lot of this stuff has been talked about before  :D
Offline 01sahara
advice needed
« Reply #9 on: September 20, 2006, 11:34:39 AM »
Quote from: "JasonL_031"
See Bill (bnine) if you want someone to do your clutch. His price is alot  beter than the dealership rate. I just had a dealership do mine and it was over $1,100.
