Author Topic: Who has suffered damage due to the cold?  (Read 4141 times)
Offline Waytec
  • not all there
« on: January 29, 2008, 09:19:50 PM »
Man it cold.  :(
So who has suffered damage due to the cold, even the best maintained rig will suffer due to this cold.
I personally got one of those custom rounded out battery's. At work we have lots of issues, nothing wants to start, new equipment coming up from the south has gelled fuel, frost plugs out, and even hyd fluid that wound pump.  :-\
So lets hear if anyone has experienced anything.
The obstacle is the path.
Offline apex
Re: Who has suffered damage due to the cold?
« Reply #1 on: January 29, 2008, 09:28:04 PM »
uhmmm... where to start. At work... cant load/unload trucks because the powerlift gates don't move. Mission critital equipment stuck on a truck....Forklifts suddenly die... it's great! Unloading a 3ton Hino loaded full of metal cases down a ramp at 8am was a blast.
And my tranny hates 2nd gear all the sudden.
Offline Hi Lo Silver
« Reply #2 on: January 29, 2008, 09:42:00 PM »
I work outside for a living. This cold is brutal. Damage suffered so far...butt must be  getting bigger cause I can't seem to get off the couch. ;D
Offline Elsifer
« Reply #3 on: January 29, 2008, 09:49:01 PM »
The plastic dogs/clips that hold the shifter boot broke, now the shifter boot flaps around until the plastic warms up and it sits back down.
Thinks this weekend I'm gonna replace plastic with a metal frame to hold the boot down.
VA6CPL
Jeepless....
Offline murdajeep
« Reply #4 on: January 29, 2008, 09:52:09 PM »
i second the stiff second gear.  takes 5 mins driving till it get's loose again.
Won't shift into 4wd when I go into a field...or if i do get it into 4wd won't
shift out lol
gotta love good old saskabush winters!!
This is my first winter here and I am frozen.  My rez dorn window is so shitty snow sometimes blows in
when the winds are bad!!
Murdajeep
Offline yyc_tbird_sc
« Reply #5 on: January 29, 2008, 09:53:41 PM »
I used to work outside at the airport loading and deicing planes with WestJet. Please....in this weather, don't get mad at the people out there on the ramp, they're doing their best and alot of times they're out there working for hours at a time.
My truck's new radiator decided to start leaking from the end tank, so I had to buy a new one and send the old one back to see if I can get a refund under the warranty. And now the brand new one is busted from cheap manufacturing.
Offline apex
« Reply #6 on: January 29, 2008, 10:06:52 PM »
I forgot to mention... the little plastic cord that ties the gas cap to the body snapped. Oh me, oh my.
Cementhead
« Reply #7 on: January 29, 2008, 11:39:53 PM »
I was wonderin if any of you guys could tell me why my '07 jeep wrangler sounds like the gears are grinding to crap when i first start it up. All i do is put in the clutch and turn the key and it sounds like its dying for bout 2 seconds whether i take my foot off the clutch or not.
And of course 2nd is a pain till it warms up for a bit.
Oh work wise i was on holidays and had to pick up a part time job cause concrete doesnt like the cold and neither does my truck.
Good luck to yall over the next few weeks
« Reply #8 on: January 30, 2008, 08:55:27 AM »
Nathan was mentioning the starter sticking on their new heep.  i remember my 97 avenger when -1 or colder there was always a grrrrrrrrrrrr sound after starting.  took it in and left it overnight and the dealership said there was no sound, even though it happened every single time for like 2 months.
anyway, our liberty does it at about -10 or colder most of the time.  my gmc van did it yesterday but i never plug it in.  i'm not convinced it is the starter or if it is, that it is the gears crunching.  the avenger went 8 years doing this every wintery start - even if it was just sitting a few hours in the day it would do it again.  never a starter issue.
the sound was more like a vibration as well.  i remember on really cold days like this week, the avenger would make the noise for 30 seconds or more after starting, revving would make it louder but never sounded faster.  eventually i ignored it like i do now.
Tribal Jeep
« Reply #9 on: January 30, 2008, 09:19:41 AM »
well.. I got Angry Sparrows living in the front drive shaft, and now this morning there is a Frog living in the dashboard lol! If the Heep keeps this up it'll have mice living in the tailpipe!
plus a sticky starter.
Offline XJHERO
  • Soberphobic
« Reply #10 on: January 30, 2008, 09:43:33 AM »
yup starter is stikin after jeep starts sounds like this vvvvrroommmzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz ;D
Brand new jeep should not do that :P
DD
Get at me Wolf
yjcanibul
« Reply #11 on: January 30, 2008, 12:21:27 PM »
yj did this monday - slight whirl to the starter after it was running,  next startup I noticed the ignition wasnt returning all the way to running pos so I gave it a little help ... seems to have gone away or coincidence ...
also - liberty makes some brutal sounds on startup ...
Offline RedApe
    • http://www.island4x4.com
« Reply #12 on: January 30, 2008, 10:15:52 PM »
Not alone....not alone....I'm not alone.
TJ Cold
- Shifter boot = off.
- Clutch pushed to floor, took 2 mins before it came back up.
- Drivers door lock no worky
- Drivers door lever broke off (interior)
- Passenger door wouldn't unlock (crawled in through rear gate this morn - limbo under Highlift)
- Defrost not pushing air to windshield...but my feet are warm
- TRXUS display bias ply "flat spots" for first 4-5 blocks of driving
XJ Cold
- Remote start's range INCREASED by 50%!
- increased vibration in Full Time AWD (Select-Trac)
- windshield wipers now "quiver"
 :P
Keith <aka RedApe>
94 XJ <his>
97 TJ <hers>
Four Wheel Stampeders member
Offline Gearhead
« Reply #13 on: January 30, 2008, 10:48:08 PM »
The starter in the 88 is not liking this cold , 185 lbs cranking pressure doesn't help, i'll be lucky if the starter makes it thru this .It's been dunked and packed with mud many times and starting to sound funny , the one way clutch is slipping  when it's low twenties or colder. The seats are pretty solid for the first ten minutes , other than that , all is good. My new cold air intake sounds mean 8)
Oh  ya , hard tops are for sissies.
Matty__e
« Reply #14 on: January 31, 2008, 10:03:23 AM »
well well...I purchased my jeep in november...had it a week and well due to the cold and the city using rocks for the road i got my windshield cracked...There should be a voucher that you get everytime you drive on deer foot for a new windshield.  Also last week another rock decided to take out my headlight....I guess me and deerfoot just don't work.  Can't wait for summer...ahhhhhhhhhhh 8)
