Author Topic: Blinker Mod  (Read 5810 times)
Offline Elsifer
Blinker Mod
« on: August 29, 2006, 06:35:48 AM »
Anyone do the blinker-relay mod as per http://www.stu-offroad.com/electrical/led1/led-4.htm ??
I was at B&E, picked up a similar relay, with different pinout.
I got my flashers to flash normally (say that three times fast).
But the dash indicator for the arrows comes on when I turn on my lights. As if to tell me I have a bulb out.
Can anyone verify this behaviour? Or have I mis-soldered something?
Cheers
Chris
VA6CPL
Jeepless....
Offline calltrex
Blinker Mod
« Reply #1 on: August 29, 2006, 06:37:51 PM »
You can buy flashers if u have led tail lights.
I bought one for the jeep.  plug it in and its done. works like a charm
I wouldnt wasted your time trying to modify..
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Offline Elsifer
Blinker Mod
« Reply #2 on: August 29, 2006, 08:41:45 PM »
Quote from: "calltrex"
Do you have a part number and location where I can get this said flasher?
And does it work in an 01 and newer tj? With the integrated relay/flasher module?
Chris
VA6CPL
Jeepless....
Offline redbull
Re: Blinker Mod
« Reply #3 on: August 29, 2006, 09:53:03 PM »
Quote from: "Elsifer"
Interesting. Probably not seeing the correct resistance. We get this all the time on motorcycles that have removed the stock signals for LEDs.
t's a simple fix, wire in some resistors. Depending on the stock bulb wattage, a 20W-8ohm resistor (or a series pair of 10W-4ohm) resistors wired in parrallel to the LEDs should do the trick. Assuming about a 27W max load (1157 stock bulb). Use your Ohm/Watt's laws from high school to figure out the proper resistor for a different load.
Of course, a HD flasher is a lot less work if you can find one!  :D
Offline Rookie
  • build it, break it, rebuild it better
Blinker Mod
« Reply #4 on: August 30, 2006, 12:34:59 AM »
Don't put in the resistors they add heat and currunt draw to the system
I did my led install and flasher mod on Sunday and everything works just like stock
I don't think there is a flasher avalible for the 2001 and up tj to correct for Led lights
Chris
Sounds like u mis-soldered something
this is the link for the flasher mod that I followed
http://www.mesa4x4.com/tech_articles/flasher_2/flasher_2.html
If u still have problems let me know
HTH
Steve
TJ with some stuff
Blinker Mod
« Reply #5 on: August 30, 2006, 05:43:33 AM »
Quote from: "Rookie"
Chris
HTH
Steve
Where did you get the relay Steve? I have tried to find it at RS but they told me they didn't carry it anymore.
Vince
Offline Rookie
Blinker Mod
« Reply #6 on: August 30, 2006, 10:03:23 AM »
Quote from: "Vinman"
Vince
Vince I got one at Active on 32nd I can't remember the part # but I can stop in on thurs and get it
the specs on it are
coil 12v
contacts 1A @24V
DPDT
aprox sixe L3/4" * H1/2" * D3/8"
HTH
Steve
TJ with some stuff
Offline Elsifer
Blinker Mod
« Reply #7 on: August 30, 2006, 04:49:27 PM »
After asking the sparky at work, I have mis-soldered mine.
I got mine at B&E on Manitou Road 24VDC/3A SPDT, 15.7mm x 10.9 mm x 12mm, three bucks something.
I have the pinout and schematic to solder it up, for those who couldn't read a circuit diagram (ie me).
About to re-solder now, I'll let you know how it goes.
Cheers
Chris
VA6CPL
Jeepless....
Offline Rookie
Blinker Mod
« Reply #8 on: August 30, 2006, 06:48:20 PM »
Cheers
Chris
Chris is the coil 12V?
TJ with some stuff
Offline Elsifer
Blinker Mod
« Reply #9 on: August 30, 2006, 07:17:25 PM »
Not sure, the datasheet doesn't tell me, or I don't know how to read it.
The relay says 12VDC, 3A 125VAC
The method I'm using is the same across both links above, same pictures and writeup, just different sites.
OK, I'm not a circuit analysis kinda guy, here is a ghetto schematic of the relay, how would I wire it up???
pin#1 |o --     --o| pin #2
pin #3 |o--coil---o| pin#4
pin #5 |o ------- o| pin#6
Dang forum software is not making my spaces into spaces, anyways the schematic is on the link. I'm sure you can figure it out.
I had ign to pin #3
pin#4 jumped to pin#2
pin#2 to ground
ping #6 to sw
And I get normal flash frequency, but on dash indicators lit.
Datasheet is here http://www.songchuan.com/PPDF/842.PDF
regular 842 type
Chris
VA6CPL
Jeepless....
Offline calltrex
Blinker Mod
« Reply #10 on: August 30, 2006, 07:21:40 PM »
You guys sure make a lot of work for yourself...  buy this, buy that, solder this, etc
Just buy the led flasher and plug it in. Took me 1 minute. Done.
........___________
.../""""/........J
Blinker Mod
« Reply #11 on: August 30, 2006, 07:23:13 PM »
As far as I know, there is no off the shelf LED flasher for the newer TJ's
Offline calltrex
Blinker Mod
« Reply #12 on: August 30, 2006, 07:38:38 PM »
I should have kept the box. Cost like $15 bucks
Its a blue module that plugs into the flasher socket.
........___________
.../""""/........J
Offline Elsifer
Blinker Mod
« Reply #13 on: August 30, 2006, 08:19:14 PM »
And now it seems I've pooched my blinker undoing what I've done  :cry:
*sigh* oh well, I'll call the dealerships and see who has one I can grab.
VA6CPL
Jeepless....
Offline calltrex
Blinker Mod
« Reply #14 on: August 30, 2006, 08:54:42 PM »
Chris, chris, chris... I told you where you could get the led flasher.  Now look what u done.  Naughty boy.
........___________
.../""""/........J
